Ana içeriğe geç
Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement
Neye ihtiyacın var
  1. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement, Remove Cover: adım 1, 1 resimden 1.
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: adım 2, 1 resimden 1.
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: adım 3, 1 resimden 1.
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: adım 4, 2 resimden 1. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: adım 4, 2 resimden 2.
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: adım 5, 1 resimden 1.
    • Grip the analog stick you wish to remove and the smaller circuit board or the cover.
    • Pull the analog stick from the smaller circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alexander Coyne
658 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 610
