Ana içeriğe geç
Mad Catz Dual Force 2 Pro Buttons Replacement
Neye ihtiyacın var
  1. Mad Catz Dual Force 2 Pro Buttons Replacement, Buttons: adım 1, 1 resimden 1.
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 4, 2 resimden 1. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 4, 2 resimden 2.
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 5, 1 resimden 1.
    • Remove the two 7 mm Philip screws on the larger circuit board.
  6. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 6, 2 resimden 1. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 6, 2 resimden 2.
    • Remove the motherboard assembly from the cover.
  7. Mad Catz Dual Force 2 Pro Buttons Replacement: adım 7, 1 resimden 1.
    • Lift out any of the plastic buttons you want to replace.
Sonuç
Alexander Coyne
658 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Remmell Winter 2015 USF Tampa, Team 7-2, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 521
