Ana içeriğe geç
Mad Catz Rock Band 4 Wireless Fender Power Button Replacement
Neye ihtiyacın var
  1. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: adım 2, 1 resimden 1.
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: adım 3, 1 resimden 1.
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Power Button: adım 4, 1 resimden 1.
    • Using a size J1 philips head screwdriver, remove the two black 5 mm screws (circled in red) from the back of the power button component. You can identify this by the code J5-B on the component.
  5. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: adım 5, 1 resimden 1.
    • Using your hands, lift the small, rectangular circuit board off and follow the connecting cords to the main circuit board.
    • Unplug the cord connected to the battery component from the main circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Catherine Lintner
581 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
I need two Rock Band 4 Home Button/Bluetooth Replacement Parts, where to locate??
My name is Robert.
Thank you in regards to whom can assist
Robert Houser Jr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 3,222
