Giriş
The power button is what allows your Mad Catz Rock Band 4 Wireless Fender to turn on and off. If your power button has stopped working, try putting new batteries in the back of the guitar before starting this replacement guide. If that does not work, follow the steps listed below.
Be sure to remove the batteries before beginning.
Neye ihtiyacın var
Flip the guitar over so it is back side up. The battery compartment should be facing up.
Use a size J1 head screwdriver to remove the ten 5 mm short screws.
Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
Using a size J1 philips head screwdriver, remove the two black 5 mm screws (circled in red) from the back of the power button component. You can identify this by the code J5-B on the component.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I need two Rock Band 4 Home Button/Bluetooth Replacement Parts, where to locate??
My name is Robert.
Thank you in regards to whom can assist
