Giriş
The strum bar is the approximately two inches long white bar on the Mad Catz Rock Band 4 Wireless Fender. Being one of the main components used to play Mad Catz Rock Band 4, it is prone to breakage after long hours of gaming. This guide is to help you figure out how to replace the strum bar in case of any causalities.
Be sure to remove the batteries before beginning.
Neye ihtiyacın var
Flip the guitar over so it is back side up. The battery compartment should be facing up.
Use a size J1 head screwdriver to remove the ten 5 mm short screws.
Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
Using a size J1 head screwdriver, remove the six black 5 mm screws (circled in red) from the back of the strum button component.
Bir başkası bu kılavuzu tamamladı.
