Ana içeriğe geç
Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
Neye ihtiyacın var
  1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: adım 2, 1 resimden 1.
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: adım 3, 1 resimden 1.
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: adım 4, 1 resimden 1.
    • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
    • Lift the small, rectangular circuit board out and set it aside.
  5. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: adım 5, 1 resimden 1.
    • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
    • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
  6. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: adım 6, 1 resimden 1.
    • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hollynn Ricker
451 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 2,307
