Ana içeriğe geç
Mad Catz Rock Band 4 Wireless Fender Whammy Bar Replacement
Neye ihtiyacın var
  1. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: adım 2, 1 resimden 1.
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: adım 3, 1 resimden 1.
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Whammy Bar: adım 4, 1 resimden 1.
    • Using a size J1 philips head screwdriver, remove the four black 5 mm screws (circled in red) from the cover on the whammy bar component.
  5. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: adım 5, 1 resimden 1.
    • Using your hands, pull off the black cover and put the spring that pops out aside.
  6. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: adım 6, 1 resimden 1.
    • Using your hands, pull out the rectangular circuit board from the whammy bar component.
  7. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: adım 7, 1 resimden 1.
    • Follow the cord for the circuit board from the whammy bar, and using your hands pull it out of the main circuit board.
  8. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: adım 8, 1 resimden 1.
    • Pull out the whammy bar.
Sonuç
Catherine Lintner
581 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Cagle Fall 2016 USF Tampa, Team 1-1, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 1,669
