Giriş
The whammy bar on the Mad Catz Rock Band 4 Wireless Fender is the silver lever sticking out of the device to the left of the power button. It is possible for the whammy bar to break or become faulty, needing to be replaced.
Be sure to remove the batteries from the device before beginning.
Neye ihtiyacın var
Flip the guitar over so it is back side up. The battery compartment should be facing up.
Use a size J1 head screwdriver to remove the ten 5 mm short screws.
Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
Using a size J1 philips head screwdriver, remove the four black 5 mm screws (circled in red) from the cover on the whammy bar component.
