Ana içeriğe geç
Mad Catz Street Fighter IV FightPad Buttons Replacement
Neye ihtiyacın var
  1. Mad Catz Street Fighter IV FightPad Buttons Replacement, Rear and Side Case: adım 1, 1 resimden 1.
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 2, 1 resimden 1.
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 3, 2 resimden 1. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 4, 2 resimden 1. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Buttons Replacement, RS-DP-LS Switch: adım 5, 2 resimden 1. Mad Catz Street Fighter IV FightPad Buttons Replacement, RS-DP-LS Switch: adım 5, 2 resimden 2.
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Buttons Replacement, Circuit Board: adım 6, 1 resimden 1.
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 7, 3 resimden 1. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 7, 3 resimden 2. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 7, 3 resimden 3.
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  8. Mad Catz Street Fighter IV FightPad Buttons Replacement, Buttons: adım 8, 2 resimden 1. Mad Catz Street Fighter IV FightPad Buttons Replacement, Buttons: adım 8, 2 resimden 2.
    • Remove the six buttons one by one by gripping the back of each one and pushing on them from the front.
    • Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
    • When reinserting the buttons make sure they are in the correct place and oriented correctly.
  9. Mad Catz Street Fighter IV FightPad Buttons Replacement: adım 9, 1 resimden 1.
    • Remove the left and right shoulder buttons by sliding them out of their respective slots.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Eric
117 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G7
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 2,524
