Ana içeriğe geç
Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement
Neye ihtiyacın var
  1. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement, Rear and Side Case: adım 1, 1 resimden 1.
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement: adım 2, 1 resimden 1.
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement: adım 3, 2 resimden 1. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement: adım 4, 2 resimden 1. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement: adım 4, 2 resimden 2.
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement, RS-DP-LS Switch: adım 5, 2 resimden 1. Mad Catz Street Fighter IV FightPad RS-DP-LS Switch Replacement, RS-DP-LS Switch: adım 5, 2 resimden 2.
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jefferson Hsu
411 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-7, Propen Fall 2012 Cal Poly, Team 1-7, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G7
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 1,459
