Ana içeriğe geç
Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement
Neye ihtiyacın var
  1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement, Joystick: adım 1, 1 resimden 1.
    • Unplug your controller from your console or pc.
  2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 2, 3 resimden 1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 2, 3 resimden 2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 2, 3 resimden 3.
    • Remove the four 3mm screws with a Philips #0 screwdriver.
  3. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 3, 3 resimden 1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 3, 3 resimden 2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 3, 3 resimden 3.
    • Remove the six 0.9mm screws with a Phillips #00 screwdriver.
  4. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 4, 2 resimden 1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 4, 2 resimden 2.
    • Remove the metal plate cover.
    • Find the lever inside of the controller.
  5. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 5, 3 resimden 1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 5, 3 resimden 2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 5, 3 resimden 3.
    • Insert your Flathead screwdriver into the middle of the lever to hold it in place.
    • Twist the ball to remove it from the lever.
    • Remove the ball top from the lever.
  6. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 6, 2 resimden 1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 6, 2 resimden 2.
    • Remove the four 1.1mm screws holding the lever in place with your Phillips #0 screwdriver.
  7. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 7, 1 resimden 1.
    • Remove the lever from the casing of the controller.
  8. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 8, 2 resimden 1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: adım 8, 2 resimden 2.
    • Pull the cable connected to the lever out of the socket.
    • Remove the lever from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan
184 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 45
Son 30 gün: 208
Her zaman: 2,204
