Ana içeriğe geç
Magellan RoadMate 1200 Back Cover Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: adım 2, 1 resimden 1.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: adım 3, 2 resimden 1. Magellan RoadMate 1200 Back Cover Replacement: adım 3, 2 resimden 2.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: adım 4, 2 resimden 1. Magellan RoadMate 1200 Back Cover Replacement: adım 4, 2 resimden 2.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ross Light
217 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 15
Her zaman: 3,482
