Giriş
You can change the battery by opening up the GPS.
Neye ihtiyacın var
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Disconnect the battery connector from the circuit board.
Pry the battery off the circuit board. The adhesive attaching it shouldn't require any other tools.
4 farklı kişi bu kılavuzu tamamladı.
