Ana içeriğe geç
Magellan RoadMate 1200 Motherboard Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 1200 Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Magellan RoadMate 1200 Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Motherboard Replacement: adım 3, 2 resimden 1. Magellan RoadMate 1200 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Motherboard Replacement: adım 4, 2 resimden 1. Magellan RoadMate 1200 Motherboard Replacement: adım 4, 2 resimden 2.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the two screws on that are located on opposite sides of the board.
  6. Magellan RoadMate 1200 Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ross Light
217 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 5,022
