Giriş
After this guide, the logic board will be completely removed.
Parçalar
Hiçbir parçaya gerek yok.
  1. Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Please note: this is a tedious process, but be patient.
    Yorum Ekle
  2. Remove the 4 screws holding the cover in place using a Philips #00 screwdriver.
    • Remove the 4 screws holding the cover in place using a Philips #00 screwdriver.
    Yorum Ekle
    • Open the back cover.
    • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
    Yorum Ekle
    • Disconnect the speaker from the terminal.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
    In my 1200, the speaker is glued to the back and soldered into the board so there is no plug to undo. Just carefully find a position so that board doesn't pull on the speaker wire while it is open.
    Jomar - Yanıt
    where can we get the speakers from? please
    bbunni1404 - Yanıt
    • Unscrew the 2 screws on either side of the board.
    For me, there were two screws, just located at the corners. One was near where the speaker is soldered to the board and the other was diagonally across the board where the GPS unit is soldered into the board.
    Jomar - Yanıt
    • Lift the circuit board up and disconnect the GPS connector.
    My GPS unit, as mentioned, is soldered into the board, so no conector to remove. The GPS unit lifted right out with the board and was not attached to the display at all.
    Jomar - Yanıt
    • Peel back the tape securing the display connector to the logic board.
    My Roadmate 1200 had no tape holding the ribbon cable. Instead, on the board is a thin stripe of black plastic which is the connector for the cable. You can catch your finger nail under the edge of the black plastic strip closest to where the ribbon enters the board. Gently lever it up and it pivots up and out of the way as it releases the ribbon cable. The cable then easily slide out. When you align and slide in the new cable, just gently push the strip back down and it will snap into place. Practice aligning the cable a few times with the old one, snapping it in place, before installing the new.
    Jomar - Yanıt
    • Remove the display connector from the device.
    • Do not pull on the cable because you may damage it. Instead, try to pull as closely as you can to the plug.
    Yorum Ekle
Sonuç
Ross Light
175 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 2,365
