Ana içeriğe geç
Magellan RoadMate 1440 Power Switch Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: adım 1, 1 resimden 1.
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Power Switch Replacement: adım 2, 2 resimden 1. Magellan RoadMate 1440 Power Switch Replacement: adım 2, 2 resimden 2.
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Power Switch Replacement: adım 3, 2 resimden 1. Magellan RoadMate 1440 Power Switch Replacement: adım 3, 2 resimden 2.
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Power Switch Replacement: adım 4, 3 resimden 1. Magellan RoadMate 1440 Power Switch Replacement: adım 4, 3 resimden 2. Magellan RoadMate 1440 Power Switch Replacement: adım 4, 3 resimden 3.
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Power Switch Replacement: adım 5, 3 resimden 1. Magellan RoadMate 1440 Power Switch Replacement: adım 5, 3 resimden 2. Magellan RoadMate 1440 Power Switch Replacement: adım 5, 3 resimden 3.
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: adım 6, 1 resimden 1.
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
Sonuç
Jeremy Johnson
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-3, Benson Spring 2016 Clemson, Team 7-3, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 191
