Ana içeriğe geç
Magellan RoadMate 1440 Screen Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 1440 Screen Replacement, Magellan RoadMate 1440 Back Cover Disassembly: adım 1, 1 resimden 1.
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Screen Replacement: adım 2, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Screen Replacement: adım 3, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 3, 2 resimden 2.
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Screen Replacement: adım 4, 3 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 4, 3 resimden 2. Magellan RoadMate 1440 Screen Replacement: adım 4, 3 resimden 3.
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Screen Replacement: adım 5, 3 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 5, 3 resimden 2. Magellan RoadMate 1440 Screen Replacement: adım 5, 3 resimden 3.
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Screen Replacement, Battery: adım 6, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement, Battery: adım 6, 2 resimden 2.
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Screen Replacement: adım 7, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Screen Replacement: adım 8, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 8, 2 resimden 2.
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
  9. Magellan RoadMate 1440 Screen Replacement, Screen: adım 9, 1 resimden 1.
    • Replace the device's screen.
  10. Magellan RoadMate 1440 Screen Replacement: adım 10, 3 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 10, 3 resimden 2. Magellan RoadMate 1440 Screen Replacement: adım 10, 3 resimden 3.
    • It may be necessary to get help from a friend to hold the device stable while removing the screen.
    • Using two hands, pull back the tabs holding the screen in place.
    • Use a spudger to help use leverage to remove the screen, if necessary
  11. Magellan RoadMate 1440 Screen Replacement: adım 11, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 11, 2 resimden 2.
    • Raise the switch locking the ribbon cable in place.
    • Using twesers, pull the ribbon cable from the socket.
  12. Magellan RoadMate 1440 Screen Replacement: adım 12, 2 resimden 1. Magellan RoadMate 1440 Screen Replacement: adım 12, 2 resimden 2.
    • With the ribbon cable removed, the screen is completely disconnected from the device.
    • To replace the ribbon cable, press the two tabs to push the head into the socket.
Sonuç
Miller Hall
325 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-3, Benson Spring 2016 Clemson, Team 7-3, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 428
