Ana içeriğe geç
Magellan RoadMate 2120T-LM Motherboard Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: adım 1, 3 resimden 1. Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: adım 1, 3 resimden 2. Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 2, 2 resimden 1. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the four 3 mm Phillips #1 screws from the motherboard.
    • In the picture three out of four screws have already been removed.
  6. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 6, 2 resimden 1. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove black tape covering connection ribbon for touch-screen
  7. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 7, 3 resimden 1. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 7, 3 resimden 2. Magellan RoadMate 2120T-LM Motherboard Replacement: adım 7, 3 resimden 3.
    • Pull up on the brown tab holding down the ribbon.
    • In this picture the brown tab has already been lifted.
    • Lift up on the motherboard and remove it from device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 228
