Ana içeriğe geç
Magellan RoadMate 5120-LMTX Battery Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: adım 1, 3 resimden 1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: adım 1, 3 resimden 2. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Battery Replacement: adım 2, 3 resimden 1. Magellan RoadMate 5120-LMTX Battery Replacement: adım 2, 3 resimden 2. Magellan RoadMate 5120-LMTX Battery Replacement: adım 2, 3 resimden 3.
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: adım 3, 2 resimden 1. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
    • Still using the spudger tool, pry the battery from the housing.
    • If you damage the tape while trying to remove the battery, you can replace it with any double-sided tape.
  4. Magellan RoadMate 5120-LMTX Battery Replacement: adım 4, 3 resimden 1. Magellan RoadMate 5120-LMTX Battery Replacement: adım 4, 3 resimden 2. Magellan RoadMate 5120-LMTX Battery Replacement: adım 4, 3 resimden 3.
    • Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
    • There is a clear rectangular adhesive strip that also needs to be removed with the pointy end of a spudger.
    • Slowly pull the connection from the motherboard.
    • Do not pull too hard or you will risk damaging the wires.
Sonuç
Steven Prout
231 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016 üyesi
IUPUI-WILSON-F16S4G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 474
