Ana içeriğe geç
Magellan RoadMate 5120-LMTX Motherboard Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 2, 3 resimden 1. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 2, 3 resimden 2. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 2, 3 resimden 3.
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
  4. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 4, 3 resimden 1. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 4, 3 resimden 2. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 4, 3 resimden 3.
    • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
    • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
    • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
    • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
  5. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 5, 2 resimden 1. Magellan RoadMate 5120-LMTX Motherboard Replacement: adım 5, 2 resimden 2.
    • Be careful not to touch any of the electrical components on the motherboard as damage may ensue.
    • Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
    • Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
Sonuç
Andrew Bading
132 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016 üyesi
IUPUI-WILSON-F16S4G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 306
