Giriş
You will be removing many pieces of hardware during this process. Store all of these pieces in a safe location so as not to lose them. Also, save all the pieces of tape and/or plastic that will be removed as they are very important in securing wires internally.
Neye ihtiyacın var
There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
