Ana içeriğe geç
Magellan RoadMate 5120-LMTX Speaker Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: adım 1, 3 resimden 1. Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: adım 1, 3 resimden 2. Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Speaker Replacement: adım 2, 3 resimden 1. Magellan RoadMate 5120-LMTX Speaker Replacement: adım 2, 3 resimden 2. Magellan RoadMate 5120-LMTX Speaker Replacement: adım 2, 3 resimden 3.
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: adım 3, 2 resimden 1. Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Open the device and remove the tape from the speaker wire using the spudger.
  4. Magellan RoadMate 5120-LMTX Speaker Replacement: adım 4, 2 resimden 1. Magellan RoadMate 5120-LMTX Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the two 4mm Phillips #00 screws securing the speaker assembly and remove speaker.
Sonuç
Chris Blaskowski
370 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016 üyesi
IUPUI-WILSON-F16S4G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 135
