Ana içeriğe geç
Magellan RoadMate 5236T-LM Display Screen Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: adım 1, 3 resimden 1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: adım 1, 3 resimden 2. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: adım 1, 3 resimden 3.
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: adım 2, 3 resimden 1. Magellan RoadMate 5236T-LM Display Screen Replacement: adım 2, 3 resimden 2. Magellan RoadMate 5236T-LM Display Screen Replacement: adım 2, 3 resimden 3.
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: adım 3, 2 resimden 1. Magellan RoadMate 5236T-LM Display Screen Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: adım 4, 3 resimden 1. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: adım 4, 3 resimden 2. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: adım 4, 3 resimden 3.
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Megan Scribner
315 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G7
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 586
