Ana içeriğe geç
Magellan RoadMate 5250T-LM Battery Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5250T-LM Battery Replacement, Battery: adım 1, 2 resimden 1. Magellan RoadMate 5250T-LM Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove all four 5 mm screws from the back of the device using a Phillips Head screwdriver size 000.
  2. Magellan RoadMate 5250T-LM Battery Replacement: adım 2, 2 resimden 1. Magellan RoadMate 5250T-LM Battery Replacement: adım 2, 2 resimden 2.
    • Open the casing of the device using a plastic opening tool.
  3. Magellan RoadMate 5250T-LM Battery Replacement: adım 3, 2 resimden 1. Magellan RoadMate 5250T-LM Battery Replacement: adım 3, 2 resimden 2.
    • Remove the tape covering the display connector on top of the motherboard.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Battery Replacement: adım 4, 2 resimden 1. Magellan RoadMate 5250T-LM Battery Replacement: adım 4, 2 resimden 2.
    • Pry off the original battery using a spudger to break the adhesive that connects the battery to the back casing.
  5. Magellan RoadMate 5250T-LM Battery Replacement: adım 5, 2 resimden 1. Magellan RoadMate 5250T-LM Battery Replacement: adım 5, 2 resimden 2.
    • Remove the motherboard from the device by unscrewing all three 4 mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
  6. Magellan RoadMate 5250T-LM Battery Replacement: adım 6, 1 resimden 1.
    • Disconnect the original battery from the motherboard by desoldering all three wires that attach it to the motherboard.
    • Click here to refer to iFixit's soldering technique guide for this step.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Amanda
179 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 975
