Ana içeriğe geç
Magellan RoadMate 5250T-LM Screen Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5250T-LM Screen Replacement, Screen: adım 1, 2 resimden 1. Magellan RoadMate 5250T-LM Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
    • Place screws aside. Make sure they are easily accessible for reassembling the device.
  2. Magellan RoadMate 5250T-LM Screen Replacement: adım 2, 2 resimden 1. Magellan RoadMate 5250T-LM Screen Replacement: adım 2, 2 resimden 2.
    • Lift the back cover using a spudger.
    • Remove back cover slowly and carefully to prevent damage.
  3. Magellan RoadMate 5250T-LM Screen Replacement: adım 3, 1 resimden 1.
    • Peel back the tape securing the display connector to the motherboard.
    • To ensure proper reassembly, do not remove or fold edges of tape.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Screen Replacement: adım 4, 2 resimden 1. Magellan RoadMate 5250T-LM Screen Replacement: adım 4, 2 resimden 2.
    • Undo the four clamps holding down the display.
    • Remove the display from the front cover.
Sonuç
Jaimee Mound
101 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 337
