Ana içeriğe geç
Magellan RoadMate 5265T-LMB Screen Replacement
Neye ihtiyacın var
  1. Magellan RoadMate 5265T-LMB Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Place the device on a flat surface with the screen facing down.
    • Remove the screws on the four corners of the device with a phillips head, size 0 screwdriver.
    • Be sure to keep track of where you place the screws. A magnetic project mat works great for this.
  2. Magellan RoadMate 5265T-LMB Screen Replacement: adım 2, 1 resimden 1.
    • Using the plastic opening tool, gently pry apart the front and back casing panels around the edges of the device. While doing this the clips will gently be pried apart allowing you to separate the front and back casings.
    • There is a ribbon cable that will still connect the front panel to the motherboard.
  3. Magellan RoadMate 5265T-LMB Screen Replacement: adım 3, 2 resimden 1. Magellan RoadMate 5265T-LMB Screen Replacement: adım 3, 2 resimden 2.
    • The ribbon cable is attached to the motherboard by a ZIF (Zero Insertion Force) connector.
    • Using the nylon or metal spudger, gently pop up the ZIF connector tab and remove the ribbon cable. This will allow you to separate the front panel from the motherboard.
    • Gently pull the front panel away and set it on your workstation.
  4. Magellan RoadMate 5265T-LMB Screen Replacement: adım 4, 2 resimden 1. Magellan RoadMate 5265T-LMB Screen Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to push back the casing clips that hold the screen in place.
    • Applying light pressure against these clips will allow you to safely remove the screen from the front casing.
    • Once the screen has been removed, gently place it down on your workstation.
Sonuç
Shannon McKeown
513 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-4, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G4
3 Üyeler
Bir Yorum
In the "what you need," it would be helpful to provide a source for the replacement screen. I have not found the screen in my online search.
Thomas Benedum - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 437
