Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
If your device won't turn on , you can access or replace the battery by using this guide. Also , make sure you have clean open place to work with. Make sure you have all the tools including the glue, which holds the battery to the panel.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip your device with back panel facing up.
    • Flip your device with back panel facing up.
  2. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel.
    • Unscrew four Phillips #0 screws from the back panel.
  3. Unscrew two Phillips #0 screws from the back panel. Unscrew two Phillips #0 screws from the back panel.
    • Unscrew two Phillips #0 screws from the back panel.
  4. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  5. Use a plastic opening tool to pop the right side of the panel. Use a plastic opening tool to pop the right side of the panel.
    • Use a plastic opening tool to pop the right side of the panel.
  6. Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  7. Remove the tape. Unplug the cable for the speaker. Unplug the cable for the speaker.
    • Remove the tape.
    • Unplug the cable for the speaker.
  8. Remove the cable of the battery. Tape removal is not necessary. Tape removal is not necessary.
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  9. Place the back panel gently on the table.
    • Place the back panel gently on the table.
  10. Remove the battery by using the IFIXIT plastic tool.
    • Remove the battery by using the IFIXIT plastic tool.
    • Battery is held by glue to the panel.
    • Remember to glue the new battery with the panel to keep it secure..
Sonuç
Umar siddique
201 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G5
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 209
