Ana içeriğe geç
Magellan Roadmate 9055-LM Motherboard Replacement
Neye ihtiyacın var
  1. Magellan Roadmate 9055-LM Motherboard Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: adım 1, 1 resimden 1.
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Motherboard Replacement: adım 2, 3 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 2, 3 resimden 2. Magellan Roadmate 9055-LM Motherboard Replacement: adım 2, 3 resimden 3.
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Motherboard Replacement: adım 3, 2 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 3, 2 resimden 2.
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Motherboard Replacement: adım 4, 2 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Motherboard Replacement: adım 5, 1 resimden 1.
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Motherboard Replacement: adım 6, 3 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 6, 3 resimden 2. Magellan Roadmate 9055-LM Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Motherboard Replacement: adım 7, 3 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 7, 3 resimden 2. Magellan Roadmate 9055-LM Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Motherboard Replacement: adım 8, 1 resimden 1.
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
  10. Magellan Roadmate 9055-LM Motherboard Replacement: adım 10, 2 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove all the electrical tapes from different places as indicated.
  11. Magellan Roadmate 9055-LM Motherboard Replacement: adım 11, 2 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the white clip attached with black and white wires.
    • Carefully remove the clip by pulling it to the opposite side from the clip.
  12. Magellan Roadmate 9055-LM Motherboard Replacement: adım 12, 3 resimden 1. Magellan Roadmate 9055-LM Motherboard Replacement: adım 12, 3 resimden 2. Magellan Roadmate 9055-LM Motherboard Replacement: adım 12, 3 resimden 3.
    • Unplug the wires by pushing it down and slowly pulling it towards you.
    • After unplugging the wires, take the motherboard out.
Sonuç
Umar siddique
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G5
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Is there a source for replacement Magellan motherboards?
Curt Cancino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 239
