Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
You can change the motherboard of the device by following this guide. When disconnecting the mother board , try to unplug all the wires carefully. Using more force can damaged the wires clips or wires it self.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip your device with back panel facing up.
    • Flip your device with back panel facing up.
  2. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel. Unscrew four  Phillips #0 screws from the back panel.
    • Unscrew four Phillips #0 screws from the back panel.
  3. Unscrew two Phillips #0 screws from the back panel. Unscrew two Phillips #0 screws from the back panel.
    • Unscrew two Phillips #0 screws from the back panel.
  4. Use a plastic opening tool to pop the right side of the panel. Use a plastic opening tool to pop the right side of the panel.
    • Use a plastic opening tool to pop the right side of the panel.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  7. Remove the tape. Unplug the cable for the speaker. Unplug the cable for the speaker.
    • Remove the tape.
    • Unplug the cable for the speaker.
  8. Remove the cable of the battery. Tape removal is not necessary. Tape removal is not necessary.
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  9. Place the back panel gently on the table.
    • Place the back panel gently on the table.
  10. Unscrew four screws in the top left corner  by using  Phillips #0 size screwdriver. Unscrew four screws in the top left corner  by using  Phillips #0 size screwdriver.
    • Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
  11. Remove all the electrical tapes from different places as indicated. Remove all the electrical tapes from different places as indicated.
    • Remove all the electrical tapes from different places as indicated.
  12. Remove the white clip attached with black and white wires. Carefully remove the clip  by  pulling it to the opposite side from the clip.
    • Remove the white clip attached with black and white wires.
    • Carefully remove the clip by pulling it to the opposite side from the clip.
  13. Unplug the wires by pushing it down and slowly  pulling it towards you. After unplugging the wires, take the motherboard out. After unplugging the wires, take the motherboard out.
    • Unplug the wires by pushing it down and slowly pulling it towards you.
    • After unplugging the wires, take the motherboard out.
Sonuç
Umar siddique
201 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G5
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Is there a source for replacement Magellan motherboards?
Curt Cancino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 198
