Ana içeriğe geç
Magic Bullet MB1001B Activator Replacement
Neye ihtiyacın var
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: adım 1, 3 resimden 1. Magic Bullet MB1001B Activator Replacement, Base Gear: adım 1, 3 resimden 2. Magic Bullet MB1001B Activator Replacement, Base Gear: adım 1, 3 resimden 3.
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
  2. Magic Bullet MB1001B Activator Replacement, Casing: adım 2, 1 resimden 1.
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Activator Replacement: adım 3, 1 resimden 1.
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Activator Replacement: adım 4, 1 resimden 1.
    • Remove the black base plate.
  5. Magic Bullet MB1001B Activator Replacement: adım 5, 1 resimden 1.
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Activator Replacement: adım 6, 1 resimden 1.
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Activator Replacement: adım 7, 1 resimden 1.
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Activator Replacement: adım 8, 1 resimden 1.
    • Remove the black base.
  9. Magic Bullet MB1001B Activator Replacement: adım 9, 1 resimden 1.
    • Remove the three white rubber spacers with the spudger.
  10. Magic Bullet MB1001B Activator Replacement: adım 10, 1 resimden 1.
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
  11. Magic Bullet MB1001B Activator Replacement: adım 11, 1 resimden 1.
    • Remove the motor.
  12. Magic Bullet MB1001B Activator Replacement, Activator: adım 12, 2 resimden 1. Magic Bullet MB1001B Activator Replacement, Activator: adım 12, 2 resimden 2.
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Aubree Duran
387 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G13
4 Üyeler
8 adet Kılavuz yazıldı
4Kılavuz Yorumları
You gotta be kidding me?
marcomolinero72 - Yanıt
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - Yanıt
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - Yanıt
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 9,635
