Giriş
Is your base gear worn down or broken? This guide will help you replace the base gear.
Neye ihtiyacın var
Use pliers to grip the gear inside of the top of the device.
Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
9 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
I am sure a black plastic piece that held the blades tight has broken off. I found pieces of it. How do I replace that piece and where can I get it? Everything is working fine, the motor is turning. The blade is too loose to stay in place while engaged.
Mine did while I was using it, looking for the same answer, I don't want to go out and buy a whole new set
It can't be that both my sets of blades are bent. Should the clear plastic piece in the turn by hand?
Mine is on but the motor is working but the blades aren't spinning
