Ana içeriğe geç
Magic Bullet MB1001B Base Gear Replacement
Neye ihtiyacın var
  1. Magic Bullet MB1001B Base Gear Replacement, Base Gear: adım 1, 3 resimden 1. Magic Bullet MB1001B Base Gear Replacement, Base Gear: adım 1, 3 resimden 2. Magic Bullet MB1001B Base Gear Replacement, Base Gear: adım 1, 3 resimden 3.
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Jackson Wiley
333 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G13
4 Üyeler
8 adet Kılavuz yazıldı
8Kılavuz Yorumları
I am sure a black plastic piece that held the blades tight has broken off. I found pieces of it. How do I replace that piece and where can I get it? Everything is working fine, the motor is turning. The blade is too loose to stay in place while engaged.
cheryl ockrant - Yanıt
Mine did while I was using it, looking for the same answer, I don't want to go out and buy a whole new set
Sheila Angeletti - Yanıt
It can't be that both my sets of blades are bent. Should the clear plastic piece in the turn by hand?
sleepyhobbit - Yanıt
Mine is on but the motor is working but the blades aren't spinning
Shenieza Singh - Yanıt
Glued too hard. The old industrial revolution greed trick of having critical parts made of plastic to interface with metal. Programmed obsolescence. Garbage once broken. This guide should be rated difficult.
Chris J - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 58
Her zaman: 21,568
