Ana içeriğe geç
Magic Bullet MB1001B Casing Replacement
Neye ihtiyacın var
    1. Magic Bullet MB1001B Casing Replacement, Base Gear: adım 1, 3 resimden 1. Magic Bullet MB1001B Casing Replacement, Base Gear: adım 1, 3 resimden 2. Magic Bullet MB1001B Casing Replacement, Base Gear: adım 1, 3 resimden 3.
      • Use pliers to grip the gear inside of the top of the device.
      • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
      • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
      • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
      FixBot'a Sor
      Yorum Ekle
    1. Magic Bullet MB1001B Casing Replacement, Casing: adım 2, 1 resimden 1.
      • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Magic Bullet MB1001B Casing Replacement: adım 3, 1 resimden 1.
      • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Magic Bullet MB1001B Casing Replacement: adım 4, 1 resimden 1.
      • Remove the black base plate.
      FixBot'a Sor
      Yorum Ekle
    4. Magic Bullet MB1001B Casing Replacement: adım 5, 1 resimden 1.
      • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Magic Bullet MB1001B Casing Replacement: adım 6, 1 resimden 1.
      • Remove the white plastic cable guide.
      FixBot'a Sor
      Yorum Ekle
    6. Magic Bullet MB1001B Casing Replacement: adım 7, 1 resimden 1.
      • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. Magic Bullet MB1001B Casing Replacement: adım 8, 1 resimden 1.
      • Remove the black base.
      FixBot'a Sor
      Yorum Ekle
    8. Magic Bullet MB1001B Casing Replacement: adım 9, 1 resimden 1.
      • Remove the three white rubber spacers with the spudger.
      FixBot'a Sor
      Yorum Ekle
    9. Magic Bullet MB1001B Casing Replacement: adım 10, 1 resimden 1.
      • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    10. Magic Bullet MB1001B Casing Replacement: adım 11, 1 resimden 1.
      • Remove the motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelly McGartland
555 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G13
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 2,164
