Ana içeriğe geç
Magic Bullet MB1001B Power Cord Replacement
Neye ihtiyacın var
    1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
      • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Magic Bullet MB1001B Power Cord Replacement: adım 2, 1 resimden 1.
      • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Magic Bullet MB1001B Power Cord Replacement: adım 3, 1 resimden 1.
      • Remove the black base plate.
      FixBot'a Sor
      Yorum Ekle
    4. Magic Bullet MB1001B Power Cord Replacement: adım 4, 1 resimden 1.
      • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Magic Bullet MB1001B Power Cord Replacement: adım 5, 1 resimden 1.
      • Remove the white plastic cable guide.
      FixBot'a Sor
      Yorum Ekle
    6. Magic Bullet MB1001B Power Cord Replacement: adım 6, 1 resimden 1.
      • Remove the two crimp caps from the end of the wires.
      • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
      FixBot'a Sor
      Yorum Ekle
    7. Magic Bullet MB1001B Power Cord Replacement: adım 7, 1 resimden 1.
      • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
      • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bridget Carr
266 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G13
4 Üyeler
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Yanıt Paylaş
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 41
Her zaman: 2,979
