Ana içeriğe geç
Magic Bullet MB1001B Power Cord Replacement
Neye ihtiyacın var
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: adım 4, 1 resimden 1.
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: adım 5, 1 resimden 1.
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: adım 6, 1 resimden 1.
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: adım 7, 1 resimden 1.
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bridget Carr
266 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G13
4 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Yanıt
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,715
