Giriş
The top of the NutriBullet powerbase contains activator switches that are depressed when the blender jar is placed onto the base. When all of the switches are depressed the blender is activated. Depending on the specific model number there may be two (NB-101B) or three (NB-301) activator switches.
This replacement guide will provide instructions on how to replace these activators on a model with 3 switches, but the steps should be reasonably similar on different models.
Neye ihtiyacın var
Wiggle the outside casing upward until it separates from the powerbase.
Bu adımda kullanılan alet:Tweezers$4.99
Place the NutriBullet powerbase on the table so that the three rubber screw covers are visible along the bottom of the well. Remove the covers using either tweezers or your fingers.
Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
62 farklı kişi bu kılavuzu tamamladı.
47Kılavuz Yorumları
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
