Ana içeriğe geç
Magic Bullet NutriBullet Base Replacement
Neye ihtiyacın var
  1. Magic Bullet NutriBullet Base Replacement, Base: adım 1, 1 resimden 1.
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: adım 2, 2 resimden 1. Magic Bullet NutriBullet Base Replacement: adım 2, 2 resimden 2.
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: adım 3, 1 resimden 1.
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Angela Wong
1.156 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G8
4 Üyeler
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
So far it was easy! Yeah!
Elaine - Yanıt
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Yanıt
Where can you buy the base to replace?
Anne-Christine von Wetter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 10,382
