Ana içeriğe geç
Magic Bullet NutriBullet Curve Base
Neye ihtiyacın var
  1. Magic Bullet NutriBullet Curve Base, Curve Base: adım 1, 1 resimden 1.
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Curve Base: adım 2, 2 resimden 1. Magic Bullet NutriBullet Curve Base: adım 2, 2 resimden 2.
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Curve Base: adım 3, 1 resimden 1.
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Curve Base: adım 4, 1 resimden 1.
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Curve Base: adım 5, 2 resimden 1. Magic Bullet NutriBullet Curve Base: adım 5, 2 resimden 2.
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Curve Base: adım 6, 1 resimden 1.
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Curve Base: adım 7, 1 resimden 1.
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geary Yu
1.244 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G8
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 55
Her zaman: 4,419
