Giriş
Is there a tear or cut in your cord? If so, refer to this guide to replace the power cord. This guide will require some soldering experience.
Neye ihtiyacın var
Before beginning, make sure the device is unplugged.
With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
3 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Can I plug the Magic Bullet in 220v?
Where can I get a replacement cable from?
