Giriş
If your Magic Bullet NutriBullet Pro won't activate, and you have determined that the activators are the culprit, follow this guide to replace them. This guide will work to replace all three activators.
Neye ihtiyacın var
To start the disassembly of the Magic Bullet NutriBullet Pro you will begin from the bottom.
Flip the device over to the bottom.
Unscrew the four 1 cm screws using #2 Phillips Head Screwdriver.
Remove the loose bottom portion of the device by pulling up from the bottom.
Remove the two 8 mm screws using the #2 Phillips Head Screwdriver while holding the activator in place.
6 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
Can you direct me to where I can buy spare parts for this bullet? As I need to replace the three black plastic moving parts that are pressed down by the lid that activates the switches.
Thankyou fir this great guide
Please can you direct me to where i can buy soare parts for this Bullet?
I need to replace the worn out 3 black plastic sliders that are pressed down by by the lid to activate it.
Many thanks
Tony
1. How do I know if culprit is activators? My spice grinder blade works, but not the blender blade and extra I bought
2. If it IS activator, do I need to buy new ones? Or just reassemble with original parts?
I thought it was the activators, since they were pretty gummed up from use. However, I believe the culprit is the mounting posts for the motor. They have rubber grommets attached to control vibration and all three of the posts the grommets go over have snapped off the mounting plate :(
I’ll try superglue, but don’t think it’s going to hold.
I’d like to remove the motor shaft from the top plate, but don’t see a way how to do that.
