Ana içeriğe geç
Magic Bullet NutriBullet Rubber Gasket Replacement
Neye ihtiyacın var
    1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: adım 1, 1 resimden 1.
      • Separate the blending blade lid from the cup.
      FixBot'a Sor
      Yorum Ekle
    2. Magic Bullet NutriBullet Rubber Gasket Replacement: adım 2, 2 resimden 1. Magic Bullet NutriBullet Rubber Gasket Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
      • Slowly pry the rubber gasket up.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geary Yu
1.277 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G8
4 Üyeler
34 adet Kılavuz yazıldı
11Kılavuz Yorumları
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Yanıt Paylaş
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Yanıt Paylaş
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Yanıt Paylaş
Thanks a lot.
Kayla Martin - Yanıt Paylaş
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 159
Her zaman: 38,452
