Ana içeriğe geç
Magic Bullet NutriBullet Rubber Gasket Replacement
Neye ihtiyacın var
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: adım 1, 1 resimden 1.
    • Separate the blending blade lid from the cup.
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: adım 2, 2 resimden 1. Magic Bullet NutriBullet Rubber Gasket Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geary Yu
1.244 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G8
4 Üyeler
13 adet Kılavuz yazıldı
11Kılavuz Yorumları
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Yanıt
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Yanıt
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Yanıt
Thanks a lot.
Kayla Martin -
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 49
Son 30 gün: 175
Her zaman: 35,584
