Ana içeriğe geç
Magnavox MWD200F Disk Drive Replacement
Neye ihtiyacın var
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: adım 2, 1 resimden 1.
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: adım 3, 1 resimden 1.
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: adım 4, 1 resimden 1.
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: adım 5, 2 resimden 1. Magnavox MWD200F Disk Drive Replacement, Disk Drive: adım 5, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: adım 6, 2 resimden 1. Magnavox MWD200F Disk Drive Replacement: adım 6, 2 resimden 2.
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: adım 7, 2 resimden 1. Magnavox MWD200F Disk Drive Replacement: adım 7, 2 resimden 2.
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: adım 8, 1 resimden 1.
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: adım 9, 2 resimden 1. Magnavox MWD200F Disk Drive Replacement: adım 9, 2 resimden 2.
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: adım 10, 3 resimden 1. Magnavox MWD200F Disk Drive Replacement: adım 10, 3 resimden 2. Magnavox MWD200F Disk Drive Replacement: adım 10, 3 resimden 3.
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: adım 11, 2 resimden 1. Magnavox MWD200F Disk Drive Replacement: adım 11, 2 resimden 2.
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Sonuç
Taryn
109 İtibar
4 adet Kılavuz yazıldı
Ekip
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011 üyesi
UMAINE-DIAZ-F11S1G2
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,489
