Ana içeriğe geç
Main Board Assembly Removal
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Main Board Assembly Removal, Prepare your PlayStation for disassembly: adım 1, 3 resimden 1. Main Board Assembly Removal, Prepare your PlayStation for disassembly: adım 1, 3 resimden 2. Main Board Assembly Removal, Prepare your PlayStation for disassembly: adım 1, 3 resimden 3.
    • Before starting your repair:
    • Shut down your console and unplug all cables and accessories.
    • Remove any stands supporting your device and lay it down.
  2. Main Board Assembly Removal, Remove the console covers: adım 2, 3 resimden 1. Main Board Assembly Removal, Remove the console covers: adım 2, 3 resimden 2. Main Board Assembly Removal, Remove the console covers: adım 2, 3 resimden 3.
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. Main Board Assembly Removal: adım 3, 3 resimden 1. Main Board Assembly Removal: adım 3, 3 resimden 2. Main Board Assembly Removal: adım 3, 3 resimden 3.
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. Main Board Assembly Removal, Remove the disc drive: adım 4, 3 resimden 1. Main Board Assembly Removal, Remove the disc drive: adım 4, 3 resimden 2. Main Board Assembly Removal, Remove the disc drive: adım 4, 3 resimden 3.
    • If your PlayStation doesn't have a disc drive, skip this step.
    • Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
    • Remove the disc drive.
    • During reassembly, place the hooks on the left edge of the drive into their cutouts and firmly press the drive into place so the connector on the bottom right corner goes into its socket.
  5. Main Board Assembly Removal, Remove the expansion slot cover screw: adım 5, 2 resimden 1. Main Board Assembly Removal, Remove the expansion slot cover screw: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  6. Main Board Assembly Removal, Remove the expansion slot cover: adım 6, 3 resimden 1. Main Board Assembly Removal, Remove the expansion slot cover: adım 6, 3 resimden 2. Main Board Assembly Removal, Remove the expansion slot cover: adım 6, 3 resimden 3.
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  7. Main Board Assembly Removal, Remove the fan cables cover: adım 7, 3 resimden 1. Main Board Assembly Removal, Remove the fan cables cover: adım 7, 3 resimden 2. Main Board Assembly Removal, Remove the fan cables cover: adım 7, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  8. Main Board Assembly Removal, Free the fan cables: adım 8, 2 resimden 1. Main Board Assembly Removal, Free the fan cables: adım 8, 2 resimden 2.
    • Gently pull the fan cables out from under their plastic clip on the frame.
  9. Main Board Assembly Removal, Disconnect the fan: adım 9, 3 resimden 1. Main Board Assembly Removal, Disconnect the fan: adım 9, 3 resimden 2. Main Board Assembly Removal, Disconnect the fan: adım 9, 3 resimden 3.
    • Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  10. Main Board Assembly Removal, Remove the fan screws: adım 10, 2 resimden 1. Main Board Assembly Removal, Remove the fan screws: adım 10, 2 resimden 2.
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
    • One 11.6 mm‑long screw
  11. Main Board Assembly Removal, Remove the fan: adım 11, 2 resimden 1. Main Board Assembly Removal, Remove the fan: adım 11, 2 resimden 2.
    • Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  12. Main Board Assembly Removal, Flip your PlayStation over: adım 12, 1 resimden 1.
    • Flip your PlayStation over.
  13. Main Board Assembly Removal, Remove the power supply screws: adım 13, 2 resimden 1. Main Board Assembly Removal, Remove the power supply screws: adım 13, 2 resimden 2.
    • Use a T8 Torx Security screwdriver to remove the two 21.3 mm‑long screws securing the power supply.
  14. Main Board Assembly Removal, Flip your PlayStation over: adım 14, 1 resimden 1.
  15. Main Board Assembly Removal, Peel up the tamper evident sticker: adım 15, 3 resimden 1. Main Board Assembly Removal, Peel up the tamper evident sticker: adım 15, 3 resimden 2. Main Board Assembly Removal, Peel up the tamper evident sticker: adım 15, 3 resimden 3.
  16. Main Board Assembly Removal, Remove the right‑side inner shell screws: adım 16, 2 resimden 1. Main Board Assembly Removal, Remove the right‑side inner shell screws: adım 16, 2 resimden 2.
    • Use a T8 Torx Security screwdriver to remove the nine screws securing the right‑side inner shell:
    • Four 18.9 mm‑long screws
    • One 21.3 mm‑long screw
    • Four 31.2 mm‑long screws
  17. Main Board Assembly Removal, Remove the right‑side inner shell: adım 17, 2 resimden 1. Main Board Assembly Removal, Remove the right‑side inner shell: adım 17, 2 resimden 2.
    • Lift the right‑side inner shell straight up and remove it.
  18. Main Board Assembly Removal, Remove the interconnect cable cover screws: adım 18, 2 resimden 1. Main Board Assembly Removal, Remove the interconnect cable cover screws: adım 18, 2 resimden 2.
    • Use a T8 Torx Security screwdriver to remove the four screws securing the interconnect cable cover:
    • One 28.7 mm‑long screw
    • Three 7.5 mm‑long screws
  19. Main Board Assembly Removal, Remove the interconnect cable cover: adım 19, 2 resimden 1. Main Board Assembly Removal, Remove the interconnect cable cover: adım 19, 2 resimden 2.
    • Remove the interconnect cable cover.
  20. Main Board Assembly Removal, Disconnect the interconnect cable: adım 20, 3 resimden 1. Main Board Assembly Removal, Disconnect the interconnect cable: adım 20, 3 resimden 2. Main Board Assembly Removal, Disconnect the interconnect cable: adım 20, 3 resimden 3.
    • Use the point of a spudger to push the interconnect cable's metal latch down and away from the connector to unlock it.
    • Keep the latch in its unlocked position and carefully pull the interconnect cable straight out of its socket.
    • During reassembly, push the latch into its unlocked position and insert the cable into its socket. Then, push the latch back in place to lock the cable.
  21. Main Board Assembly Removal, Disconnect the antenna cables: adım 21, 3 resimden 1. Main Board Assembly Removal, Disconnect the antenna cables: adım 21, 3 resimden 2. Main Board Assembly Removal, Disconnect the antenna cables: adım 21, 3 resimden 3.
    • Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
  22. Main Board Assembly Removal, Peel up the antenna cable tape: adım 22, 2 resimden 1. Main Board Assembly Removal, Peel up the antenna cable tape: adım 22, 2 resimden 2.
    • A piece of tape and a block of foam secure the antenna cables to the heatsink shield.
    • Gently lift both antenna cables to separate the tape from the heatsink shield.
  23. Main Board Assembly Removal, Peel up the antenna cable foam: adım 23, 2 resimden 1. Main Board Assembly Removal, Peel up the antenna cable foam: adım 23, 2 resimden 2.
    • Light adhesive secures the foam block to the heatsink shield.
    • Use tweezers to gently peel up the foam block.
    • If you're having trouble, heat an iOpener and apply it to the foam for one minute to soften the adhesive. If you don't have an iOpener, you can use a hair dryer instead.
  24. Main Board Assembly Removal, Reposition the antenna cables: adım 24, 3 resimden 1. Main Board Assembly Removal, Reposition the antenna cables: adım 24, 3 resimden 2. Main Board Assembly Removal, Reposition the antenna cables: adım 24, 3 resimden 3.
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
    • During reassembly, use this photo as a reference to put the antenna cables back in their original position.
  25. Main Board Assembly Removal, Lift the main board assembly: adım 25, 2 resimden 1. Main Board Assembly Removal, Lift the main board assembly: adım 25, 2 resimden 2.
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Lift the bottom left corner of the main board assembly off its gray plastic post. Keep the assembly lifted for the next step.
    • Your PlayStation's plastic housing will likely flex while lifting the assembly.
  26. Main Board Assembly Removal, Detach the power supply: adım 26, 3 resimden 1. Main Board Assembly Removal, Detach the power supply: adım 26, 3 resimden 2. Main Board Assembly Removal, Detach the power supply: adım 26, 3 resimden 3.
    • Keep the main board assembly raised with one hand.
    • With your free hand, insert your finger between the assembly and power supply.
    • Push down on the power supply and lift the assembly to separate them.
    • It'll take a significant amount of force to separate the two.
    • During reassembly, press down firmly on the bottom left corner of the main board assembly to fully connect it to the power supply.
  27. Main Board Assembly Removal, Remove the main board assembly: adım 27, 3 resimden 1. Main Board Assembly Removal, Remove the main board assembly: adım 27, 3 resimden 2. Main Board Assembly Removal, Remove the main board assembly: adım 27, 3 resimden 3.
    • Do not grab the main board assembly by the copper heat pipes or its fins, as they can easily be damaged.
    • Firmly secure the plastic housing with one hand.
    • With your free hand, grab the upper edge of the main board assembly and lift it out of the plastic housing.
    • Make sure the interconnect cable doesn't get stuck under the main board assembly when lowering it into place.
    • Lower the assembly into its recess so its prongs go into their socket on the power supply and the three cutouts go over their alignment posts.
Sonuç
Spencer Day
156.518 İtibar
1.033 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.851 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 147
