Ana içeriğe geç
Main Click Buttons
Neye ihtiyacın var
    1. Main Click Buttons, Click Buttons: adım 1, 2 resimden 1. Main Click Buttons, Click Buttons: adım 1, 2 resimden 2.
      • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
      FixBot'a Sor
      Yorum Ekle
    2. Main Click Buttons: adım 2, 2 resimden 1. Main Click Buttons: adım 2, 2 resimden 2.
      • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
      FixBot'a Sor
      Yorum Ekle
    3. Main Click Buttons: adım 3, 2 resimden 1. Main Click Buttons: adım 3, 2 resimden 2.
      • Use a blue spudger to open the bottom battery port.
      FixBot'a Sor
      Yorum Ekle
    4. Main Click Buttons: adım 4, 2 resimden 1. Main Click Buttons: adım 4, 2 resimden 2.
      • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
      FixBot'a Sor
      Yorum Ekle
    5. Main Click Buttons: adım 5, 3 resimden 1. Main Click Buttons: adım 5, 3 resimden 2. Main Click Buttons: adım 5, 3 resimden 3.
      • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
      FixBot'a Sor
      Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
how are you supposed to put the feet back?
Owen Yuen - Yanıt Paylaş
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - Yanıt Paylaş
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - Yanıt Paylaş
Are the side buttons the same?
S I - Yanıt Paylaş
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 64
Son 30 gün: 178
Her zaman: 25,682
