Ana içeriğe geç
Maisto Rock Crawler Front Axle Replacement
Neye ihtiyacın var
    1. Maisto Rock Crawler Front Axle  Replacement, Front Axle: adım 1, 2 resimden 1. Maisto Rock Crawler Front Axle  Replacement, Front Axle: adım 1, 2 resimden 2.
      • Flip the R/C truck over.
      • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
      FixBot'a Sor
      Yorum Ekle
    2. Maisto Rock Crawler Front Axle  Replacement: adım 2, 2 resimden 1. Maisto Rock Crawler Front Axle  Replacement: adım 2, 2 resimden 2.
      • Half way remove the truck top so you can unhinge the antenna from the clips.
      • Remove the R/C truck top completely.
      FixBot'a Sor
      Yorum Ekle
    3. Maisto Rock Crawler Front Axle  Replacement: adım 3, 1 resimden 1.
      • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
      FixBot'a Sor
      Yorum Ekle
    4. Maisto Rock Crawler Front Axle  Replacement: adım 4, 1 resimden 1.
      • After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Philips screws that hold the side circuit board in.
      FixBot'a Sor
      Yorum Ekle
    5. Maisto Rock Crawler Front Axle  Replacement: adım 5, 1 resimden 1.
      • Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
      FixBot'a Sor
      Yorum Ekle
    6. Maisto Rock Crawler Front Axle  Replacement: adım 6, 1 resimden 1.
      • Flip the R/C truck back over.
      • Remember which wire is connected at which pin before desoldering.
      • Desolder the 4 wires connected from the front axle to the circuit board.
      FixBot'a Sor
      Yorum Ekle
    7. Maisto Rock Crawler Front Axle  Replacement: adım 7, 1 resimden 1.
      • You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
kevin
889 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 5,593
