Ana içeriğe geç
Maisto Rock Crawler Truck Circuit Board Replacement
Neye ihtiyacın var
  1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: adım 1, 2 resimden 1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: adım 1, 2 resimden 2.
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Truck Circuit Board Replacement: adım 2, 2 resimden 1. Maisto Rock Crawler Truck Circuit Board Replacement: adım 2, 2 resimden 2.
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Truck Circuit Board Replacement: adım 3, 1 resimden 1.
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Truck Circuit Board Replacement: adım 4, 1 resimden 1.
    • Use the driver and bit J1 and remove the 7.7mm Philips screw highlighted.
  5. Maisto Rock Crawler Truck Circuit Board Replacement: adım 5, 1 resimden 1.
    • Take note of which wire is connected at which pin before desoldering. It might help to mark the wires and take a picture.
    • It would be easier to desolder and resolder only one component at a time.
    • Use the soldering iron to desolder all the wires connected to the circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
kevin
874 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G2
3 Üyeler
9 Yorum
Can you do anything to it to make it stronger are powerful
Matt John - Yanıt
Yes put a board from a nikko or ez tec in it. The 9.6 volt is the one to find and wire the motors to the single motor output. I think u have to wire one backwards to get both going right way
Mike - Yanıt
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
pankaj kapatia - Yanıt
Can any one help as my rc rock crawler is not turning left or right
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
mattilajanne - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 5,429
