Giriş
This guide will walk you through the process of replacing the truck circuit board in a Maisto Rock Crawler.
Neye ihtiyacın var
Flip the R/C truck over.
To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
3 farklı kişi bu kılavuzu tamamladı.
9 Yorum
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
Can any one help as my rc rock crawler is not turning left or right
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
What is p/n of Maisto Rock Crawler Truck Circuit Board?
Hola se conecto batería con sus polo al revés y dejo de funcionar me gustaría saber que parte de la placa se daño
good afternoon my circuit burned the q17 component i can't read the nomenclature to replace it, you could send me a picture i can only read the first 2 characters BH grazie.
Where can I find a replacement board for maisto pro series crawler 4ws ?
