Ana içeriğe geç
Makita DT01 Trigger Switch Replacement
Neye ihtiyacın var
  1. Makita DT01 Trigger Switch Replacement, Battery: adım 1, 3 resimden 1. Makita DT01 Trigger Switch Replacement, Battery: adım 1, 3 resimden 2. Makita DT01 Trigger Switch Replacement, Battery: adım 1, 3 resimden 3.
    • Lay the device down on its side.
  2. Makita DT01 Trigger Switch Replacement: adım 2, 1 resimden 1.
    • Pinch the indents on both sides of the battery.
  3. Makita DT01 Trigger Switch Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
  4. Makita DT01 Trigger Switch Replacement, Trigger Switch: adım 4, 1 resimden 1.
    • Unscrew all six 15mm screws with a JIS1 screwdriver bit.
  5. Makita DT01 Trigger Switch Replacement: adım 5, 1 resimden 1.
    • Remove the top of the plastic drill case
  6. Makita DT01 Trigger Switch Replacement: adım 6, 1 resimden 1.
    • Remove the bottom of the plastic drill case
  7. Makita DT01 Trigger Switch Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use your tweezers to remove the black wire from the motor
  8. Makita DT01 Trigger Switch Replacement: adım 8, 1 resimden 1.
    • Use your tweezers to remove the red wire from the motor
  9. Makita DT01 Trigger Switch Replacement: adım 9, 1 resimden 1.
    • Your trigger switch should now be removed from your motor
  10. Makita DT01 Trigger Switch Replacement: adım 10, 1 resimden 1.
    • Use your tweezers to remove the red and black wires from the two-pronged plug
  11. Makita DT01 Trigger Switch Replacement: adım 11, 1 resimden 1.
    • Your trigger switch is now detached from the device
Sonuç
Victoria Scira
226 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 28
Her zaman: 735
