Ana içeriğe geç
Makita Jack Hammer HM1307CB 2011 Cord Replacement
Neye ihtiyacın var
  1. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Remove six screws from the handle: adım 1, 1 resimden 1.
    • Remove the following screws:
    • Two Phillips screws
    • Four hex screws
    • These four hex screws are all held in place with threadlocker, and may take quite a bit of torque or even some heat to loosen.
    • During reassembly, clean the residual threadlocker from these screws, then reapply high-strength (red) threadlocker to each one before reinstalling.
    • If you aren't sure how to apply threadlocker, refer to the next step in this guide.
  2. Makita Jack Hammer HM1307CB 2011 Cord Replacement: adım 2, 3 resimden 1. Makita Jack Hammer HM1307CB 2011 Cord Replacement: adım 2, 3 resimden 2. Makita Jack Hammer HM1307CB 2011 Cord Replacement: adım 2, 3 resimden 3.
    • To reapply threadlocker:
    • First, clean the residual threadlocker from each of the screws with some cleaner/degreaser and a stiff brush.
    • Second, apply a couple drops of high-strength threadlocker to the screw sockets.
    • Finally, apply one or two drops of the same high-strength threadlocker to the tip of each screw and reinstall them.
  3. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Remove the handle: adım 3, 2 resimden 1. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Remove the handle: adım 3, 2 resimden 2.
    • Grab the handle and remove it from the jack hammer.
  4. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Release the power supply cord: adım 4, 1 resimden 1.
    • Remove the black Phillips screw from the strain relief plate.
    • Loosen the two silver Phillips screws that hold the stripped ends of the power cable in the green terminal on the controller. These screws do not need to be removed.
  5. Makita Jack Hammer HM1307CB 2011 Cord Replacement: adım 5, 2 resimden 1. Makita Jack Hammer HM1307CB 2011 Cord Replacement: adım 5, 2 resimden 2.
    • Remove the strain relief plate.
    • During reassembly, hook the right edge of the strain relief plate under the lip to the right of the cord before pressing it into place and reinstalling the Phillips screw.
  6. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Remove the power supply cord: adım 6, 3 resimden 1. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Remove the power supply cord: adım 6, 3 resimden 2. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Remove the power supply cord: adım 6, 3 resimden 3.
    • Remove the power supply cord from the jack hammer.
    • As you remove the cord, note the position of the cord guard. During reassembly, make sure the collar of the cord guard fits back into its slot in the handle.
    • When reinserting the two exposed wire ends into the green terminal:
    • First, compress the wire ends so they are relatively flat.
    • Then, insert each wire end into the green terminal, noting the polarity of the cables: the black cable should go into the upper slot, and the white cable should go into the lower slot (as shown in the third photo of this step).
    • Finally, gently tighten the screws until the wires are secured.
  7. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Strip replacement cable ends: adım 7, 2 resimden 1. Makita Jack Hammer HM1307CB 2011 Cord Replacement, Strip replacement cable ends: adım 7, 2 resimden 2.
    • Your replacement power supply cord may not come with stripped cable ends. If it does not, strip 6–8 mm of insulation off both the black and white cables before installing.
    • If your replacement cord does not include a cord guard, remove the cover guard from the original cord and transfer it to the new cord before installing it.
Sonuç
To reassemble your device, follow these instructions in reverse order, taking note of any applicable reassembly tips.
2 farklı kişi bu kılavuzu tamamladı.
Taylor Dixon
67.349 İtibar
94 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 2,609
